DUPLE Backup error
Duple Backup has powerful backup and restore functions, and is a disaster recovery tool designed to strengthen the data security of TNAS devices.
mutchix
DUPLE Backup error
Post by mutchix »
Hello everyone,
I've set up a duple backup to a Backblaze B2 cloud save, which worked perfectly for a year until last week. No updates or changes were made on the NAS, the backblaze setup nor the disks. The backup keep failing, and the backup status is "offline"
I can't even create a new backup on the Duple App, when browsing which shared folder to save, it fails before opening the file explorer...
Has anyone experienced the same bug ?
For information, i am still running the 4.2.09 TOS version, and a little bit reluctant to try the new updates. But maybe this is related somehow ?
Re: DUPLE Backup error
Hi! Please check if your TNAS device is connected to the Internet normally. If this happens under normal use, please send an email to our technical team and our engineer will remotely check what is causing it.
mutchix
Post by mutchix »
I have updated to TOS 4.16, and it seems that the issue has solved itself with this new version.
Thanks !
deejc
Post by deejc »
It seems the certificates got removed somehow, at least in mine I had to redownload the certs as mentioned in another post I made recently about backblaze and duplex not working
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
Return to “Duple Backup”
