[ Bazarr ] Subtitle companion application to Sonarr and Radarr
About : https://www.bazarr.media
Applicable TOS5: 5.0.135 or later versions
App download: https://tmnascommunity.eu/download/bazarr
Required packages:
Python38 > 3.8.7.3
http(s)://yournasip:port/modules/Bazarr/www
About
Bazarr is a companion application to Sonarr and Radarr that manages and downloads subtitles based on your requirements.
Automatically add new series and episodes from Sonarr
Automatically add new movies from Radarr
Series or movies based configuration for subtitles languages
Scan your existing library for internal and external subtitles and download any missing
Keep history of what was downloaded from where and when
Manual search so you can download subtitles on demand
Upgrade subtitles previously downloaded when a better one is found
Ability to delete external subtitles from disk
Currently support 184 subtitles languages with support for forced/foreign subtitles (depending of providers)
And a beautiful UI based on Sonarr
Supported subtitles providers:
Addic7ed
Argenteam
Assrt
BetaSeries
BSplayer
GreekSubtitles
Hosszupuska
LegendasDivx
LegendasTV
Ktuvit (Get hashed_password using method described here)
Napiprojekt
Napisy24
Nekur
OpenSubtitles.org
Podnapisi
RegieLive
Sous-Titres.eu
Subdivx
Subs.sab.bz
Subs4Free
Subs4Series
Subscene
Subscenter
Subsunacs.net
SubSynchro
Subtitrari-noi.ro
subtitri.id.lv
Subtitulamos.tv
Sucha
Supersubtitles
Titlovi
Titrari.ro
TuSubtitulo
TVSubtitles
Wizdom
XSubs
Yavka.net
YIFY Subtitles
Zimuku
Re: [ Bazarr ][ 0.9.9.0 ] Subtitle companion application to Sonarr and Radarr
added initial version
Re: [ Bazarr ][ 1.1.0.0 ] Subtitle companion application to Sonarr and Radarr
up to 1.1.0.0 and added TOS5 version
bhook
Re: [ Bazarr ] Subtitle companion application to Sonarr and Radarr
Post by bhook »
This is not installing and no error logs.... managed to get Sonarr installed only because it had logs and mentioned "mono" (needs mono installed!).
Any advice on how to install Bazarr (TOS 5)?
Thanks for developing these!
What exactly doesn't work? You need Python3. 8 as written on the first post. For the rest, the installation is the same as for any other app.
bhook
Post by bhook »
I have Python 3.11 installed - it just doesn't appear on the desktop
You need to install Python38
