Loosing SMB/CIFS Daily!
Tricky
Post by Tricky »
So why is my F5-221 running 4.2.15 suddenly losing SMB/CIFS on a daily basis was fine for the first few weeks, then this problem?
TMAY
Re: Loosing SMB/CIFS Daily!
Post by TMAY »
Please go to Control Panel 》Network Services》File Service to check whether the SMB/CIFS service is enabled
Does your device reboot every day? Did you mean your SMB stop service after every reboot?
Tricky
Post by Tricky »
No I mean that the SMB/CIFS service turns itself off daily despite having to re-start and re-enable because I loose the device for the network,
I have another F5-221 running the same update with the same settings on the same network that does not do the same.
TMAY
Post by TMAY »
Please try to reinstall the system to see if it can be resolved
Tricky
Post by Tricky »
TMAY wrote: 05 Oct 2021, 20:06 Hi,
Think I will wait for the next update rather than reinstall just can't be sure that won't bring on even more problems, that's the trouble with TM flaky software it makes you scared of what's going to happen next.
It's not like it happened as soon as I installed the update, it took several weeks to manifest....not confidence inspiring. :shock:
collect system report when it happens again next time, send us the report, it could help to find out what happened to your device.
Return to “File Services”
