TD2/D2 Thunderbolt 3/Thunderbolt 3 plus failed to recognize hard drives?
FAQs and instructions only for Thunderbolt series raid storage
Troubleshooting:
TD2/D2 Thunderbolt 3/Thunderbolt 3 plus failed to recognize hard drives on my MAC Big Sur 11.5.1/11.5.2?
Device failure or hard disks failure may cause the hard disk to fail to be recognized. The following troubleshooting methods are used to troubleshoot the cause of the failure.
1. Make sure you are connecting the correct original power adaptor and cable from TerraMaster;
2. Make sure you are connecting to the port on the device remarked as "PC"; Connecting to a wrong port may lead to connection failure;
3. Install only one hard drive and power on the device;
4. Go to "About this Mac" > "System report" > "Hardware" > "Thunderbold/USB 4", if your TD2/D2 is functioning well, you will find a D2 device listed here; if you do not find the device, you may be using a wrong power adaptor or the D2 device is failed, please contact our service team for warranty service or a replacement;
5. Go to "About this Mac" > "System report" > "Hardware" > "USB", if your TD2/D2 is functioning well, you will find a Terramaster controller listed here too; if you do not find the Terramaster controller here, you may be using a wrong power adaptor or the D2 device is failed, please contact our service team for warranty service or a replacement;
6. If you do find the correct device listed on "step 4" & "step 5", your Mac does not recognize your drives, this means your hard drives may be failed, please replace your drives and try again. Note: one of your two hard drives fails may affect the normal show up of the other.
