Can I replace my D5-300 without losing my datas on a RAID0 config?
fred
Post by fred »
I have to replace my D5-300 because it can't connect to computers anymore. I have 5 8Tb HDD in a RAID0 configuration. These HDD work are ok, so all my data are still there. Is there a possibility for changing only the D5-300 with a new one without losing all data?
Re: Can I replace my D5-300 without losing my datas on a RAID0 config?
Hi! If your hard disk is working normally, the data will not be damaged if you replace it with the same model device.
Hardfecx
Post by Hardfecx »
fred wrote: ↑10 Sep 2021, 15:53 I have 5 8Tb HDD in a RAID0 configuration.
Why not a Raid5 or 6, at least you have the security that your data is safe, even when one HDD stops working.
Raid 5 - one HDD can fail. Raid6 - 2 HDD's can fail.
Raid0 is only for the Speed but if one HDD fails, everything is lost
fred
Post by fred »
TMSupport wrote: ↑10 Sep 2021, 17:22 Hi! If your hard disk is working normally, the data will not be damaged if you replace it with the same model device.
It means that the 5 HDD are in RAID0 configuration and that doesn't depend on the D5-300 configuration itself?
RAID 0 is RAID 0, it always works in the same way, no matter which device.
