D5-330/TB3 driver & MacOS 11.5.2
donw
Post by donw »
I wanted to set up my new D5-330/TB3 today. Unfortunately, there are problems with the RAID driver.
I use a MacBook Pro i9 with T2-Chip and macOS Big Sur 11.5.2
I have installed the driver according to your instructions from the forum (Disable security…allow kext etc). But the kextstat is not showing up. I tries a couple of times with different releases of the Raid-driver (release date 11/17/2020, 10/26/2020 and 03/12/2021).
Only the latest driver (M1_v4.23.1 from 12th of march 2021) works…. But only if I do not reboot!
If I install this driver and leave die latest dialog (reboot) open, I am able to run the Raid-utility and create a volume.
After a reboot the driver is not loaded (or remains in the system), the new volume does not mount.
Mac T2 is still disabled.
So I have to run the driver-installation again and leave the dialog open without a reboot. Only then can I use the drive.
How can I use the drive normally?
Is there a (new) working driver for macOS 11.5.2 which also runs after reboot?
Or is there a solution to use the D5-330/TB3 without the HighPoinRRt-driver?
Re: D5-330/TB3 driver & MacOS 11.5.2
Hi! Please install version V4.13.2.
https://support.terra-master.com/downlo ... underbolt3
donw
Post by donw »
Thanks for the reply.
But the problem remains.
I have installed the driver again and followed the Instruction viewtopic.php?f=66&t=1105.
After the reboot (from Setup-dialog) my system boots up an no volume mounted.
If I check the driver with sudo su > kextstat | grep high* I only got "No variant specified, failing back to release"
The driver is not loaded or the system prevents kext extensions.
I also try this viewtopic.php?f=66&t=1106 also without success.
So I have to install driver 4.23.1 again and leave the (reboot) dialog open to access my volume...
Is it possible to use another MAC of the same system to try?
The following content may be helpful to you: viewtopic.php?f=66&t=2414
donw
Post by donw »
I will try this on my MacMini. But this Mac runs MacOS 10.15.7.
The picture below shows the current situation.
Open dialog; without reboot and working driver (4.23.1)
donw
Post by donw »
I think it has to do with the Big Sur architecture
https://developer.apple.com/de/support/ ... xtensions/
or some sandboxing issues; maybe... I'm not an expert
There is also a SoftRAID Kernel-Extension. Is this correct?
aefilho
Post by aefilho »
After many frustrating attempts following these instructions, I could make it work but only going directly to the Highpoint website.
Instructions:
https://highpoint-tech.com/PDF/RR3700/H ... _11_20.pdf
Driver:
https://highpoint-tech.com/BIOS_Driver/ ... 10_26.dmg
This is the driver version 4.22 and I can confirm it works with my iMac Pro 2017, Big Sur 11.6 with my D5 - Thunderbolt.
Remember to uninstall the driver first accordingly to the instructions and then install it.
Hope it helps.
donw
Post by donw »
@aefilho many thanks for that.
This is the solution for D5 & MacOS 11.5
The driver works and survives the reboot. Volume is accessible and works with the HighPointRR-diver 4.22.0.
Such a great board here. @Terramaster please update your support-documentations.
