Data recovery, files deleted on remote session
JheltonCoolio
Post by JheltonCoolio »
Hello, while working on remote PC (using teamviewer), accidently deleted 3gb files. It didnt ask anything, just poof and gone. Trying easeUS - no luck. Any paid service recommendation, or steps to be done? Thank You
Re: Data recovery, files deleted on remote session
Hi!
Is the recycle bin enabled in the shared folder where the file is located? If so, you can try to restore it in the recycle bin.
