Anti-Virus for F4-210
ianbhenderson73
Post by ianbhenderson73 » 09 Sep 2021, 09:23
Hello
I currently have an installation of Norton AV on my desktop and laptop computers, which is great at protecting both of those devices. However there isn't a corresponding component which can offer that same level of protection for my F4-210.
Can someone recommend for me a product that could be downloaded and subsequently installed onto the TNAS unit, and which could then update itself as and when required? I know I could theoretically run NAV scans against the TNAS unit but that would involve having the PC switched on long enough to do that, and would only read the shared sections of the TNAS when I would prefer to have a full sweep done of the unit on a scheduled basis.
I did think about downloading Clam for the TNAS but it appears not to be available as an Application any more.
TIA
titanrx8
Re: Anti-Virus for F4-210
Post by titanrx8 » 20 Sep 2021, 02:57
ianbhenderson73 wrote:
09 Sep 2021, 09:23
Hello
TIA
Clam is available for f2-221. Maybe ARM can't run it? It's a major CPU drain when it scans.
Customer Service
Post by TMroy » 20 Sep 2021, 21:44
As the ClamAV requires a lot of resources, F2-210/F4-210 are not powerful enough to support it.
Technical team: support(at)terra-master.com (for technical support only)
ianbhenderson73
Post by ianbhenderson73 » 20 Sep 2021, 23:26
TMroy wrote:
20 Sep 2021, 21:44
So does that mean there isn’t an anti virus solution for the F4-210?
Customer Service
Post by TMroy » 21 Sep 2021, 12:39
at present, it is.
