Upload files and documents from mobile app
Requirements or suggestions that have been developed and released.
lorenzo74
Post by lorenzo74 »
I have installed the mobile app on my iPhone and I have noticed that it's possible to upload just photo and video from camera roll.
Why didn't give the possibility to upload any file with other applications (like Genius Scan or similar)?
Re: Upload files and documents from mobile app
Hi! It is planned to add this feature in the future, so stay tuned.
lorenzo74
Post by lorenzo74 »
So actually there is no way to transfer files from smartphone?
I have used a work around using gdrive synch... but it's really a work around!
Hope this feature will be added soon.
titanrx8
Post by titanrx8 »
lorenzo74 wrote: ↑08 Sep 2021, 17:18 So actually there is no way to transfer files from smartphone?
I use CX File Explorer on android. Workers really well for accessing tnas system from the phone and tablet. Maybe it's available on Apple? I never use the TNAS app.
lorenzo74
Post by lorenzo74 »
titanrx8 wrote: ↑08 Sep 2021, 23:42
Thanks for your suggestion! On Apple devices there is FE File Explore... installed succesfully and works fine!
arunsdz
Post by arunsdz »
Uploading files and documents from mobile apps usually good, it FM Whatsappall depends upon the file type and data that to be uploaded. Size does matter here it took time to upload data if it is large. From my opinion if you use better smartphone more than 4gb ram can upload files and data easily and safe without any occur.
jully88
Post by jully88 »
arnolddk0 wrote: ↑28 Jan 2022, 14:11 I think you should be EX file extender download, it is the best file transfer application. nulls brawl
Well, you should try Dropbox which will help you to upload your documents and share with others peoples.
factom
Post by factom »
lorenzo74 wrote: ↑09 Sep 2021, 01:46 yes.i installed successfully and working fine.really amazing and safe ex file explore apllication.
I actually like it better than the files app on my oneplus
factom
Post by factom »
factom wrote: ↑09 Jul 2022, 07:54
lorenzo74 wrote: ↑09 Sep 2021, 01:46 yes.i installed whatsapp apk successfully and working fine.really amazing and safe ex file explore apllication.
Update : Files app started crashing frequently after Oxygen OS 12.1 update, so yeah, no files app from now on
We are going to release the new mobile app soon.
Return to “Released”
