RAM for F2-422
Hardware compatibility like hard drive, SSD, memory module, Wi-Fi adapter.
dranivil
RAM for F2-422
Post by dranivil »
I want to expand the memory of my F2-422. I have bought a 4GB module (Samsung DDR3 SODIMM 1.35v 1600MHZ cl11) but the equipment does not turn on. The module works correctly because I have tested it on another computer.
Upon opening I noticed that the RAM socket is written "DDR3 1.5v", so I thought that would be the problem. I have bought another RAM module (Kingston DDR3 4GB 1.5v sodimm 1600mhz) but the exact same thing happens.
I have tried another module I had at home (Crucial DDR3 sodimm 1.35v 2GB 1600mhz) and it doesn't work either.
I have tried looking for some compatible module, official or not, but there is no way to find it. Can someone tell me what the problem is?
Re: RAM for F2-422
Here is the compatible list of RAM sticks. To avoid compatibility issues, it recommended purchasing the official RAM sticks.
purchase links
https://www.terra-master.com/global/pro ... ories.html
or on amazon.com
Dennis_H
Re: RAM for F2-422
Post by Dennis_H »
I used this one on my F2-221 with no issues. Detects 10G and has been working for 8 months.
https://www.amazon.com/gp/product/B006Y ... UTF8&psc=1
Tricky
Re: RAM for F2-422
Post by Tricky »
I have used this one in both my NAS with no problems.
https://www.aliexpress.com/item/32617292005.html
dranivil
Re: RAM for F2-422
Post by dranivil »
TMroy wrote: ↑07 Sep 2021, 21:12 Here is the compatible list of RAM sticks. To avoid compatibility issues, it recommended purchasing the official RAM sticks.
purchase links
or on amazon.com
My model (F2-422) does not appear on the compatibility list.
Tricky wrote: ↑07 Sep 2021, 21:58 I have used this one in both my NAS with no problems.
Ddr3 or ddr3l? For what model?
Tricky
Re: RAM for F2-422
Post by Tricky »
DDR3L 1,333 MHz 1.3v. I have used 4GB and 8GB in my F5-221s.
dranivil
Re: RAM for F2-422
Post by dranivil »
Tricky wrote: ↑08 Sep 2021, 00:42 DDR3L 1,333 MHz 1.3v. I have used 4GB and 8GB in my F5-221s.
For my model is 1600mhz...
hipsi
Re: RAM for F2-422
Post by hipsi »
there doesn't seem to be a DDR3L 1333MHz in that Aliexpress store. I actually ordered the 1600MHz for this reason (which also is not listed anymore), and my F2-220 won't boot with that. :(
Tricky
Re: RAM for F2-422
Post by Tricky »
There is 1333mhz showing when I click the link.
hipsi
Re: RAM for F2-422
Post by hipsi »
DDR3L ? definitely not for me. Maybe it depends on location?
Return to “Compatibility”
