VETOFILES smb.conf resetting after services restart
deejc
Post by deejc »
i am / was experiencing this same issue as in https://forum.terra-master.com/en/view ... =24&t=1703
i have chattr +i the smb.conf after deleting the line
veto files = /desktop
and it now works but this is not a valid fix as now the conf file will never update again, i am backing up a Mac with a "Desktop" folder and unless i do this then it never works
i have got veto files enabled in the TOS GUI so that the usual apple files are not saved but why is tis file configured to also hide the Desktop ?
can i suggest that you remove this line in the next build of TOS 4 and in TOS 5 ?
F2-220 WITH 2 x WD RED 2TB RUNNING 4.2.17
Re: VETOFILES smb.conf resetting after services restart
Ok, I will inform the engineer.
Return to “File Services”
