Entering the password in the web login page cannot log in, and there is no password error prompt, and can't jump to TOS interface.
Cause:
1. Redis service failure
2. The btrfs file system is abnormal
Solution:
1. How to log in to the SSH terminal?
2. Switch to the root directory of the system.
Input:
cd /Code: Select all
sudo -iInput:
/etc/init.d/redis restartIf the above method does not work, please continue with the following steps:
4. Check the system log.
Input:
dmesgPlease input separately:
umount /mnt/md0
umount /homeInput:
btrfs check /dev/mapper/vg0-lv07. If the check takes a long time or an obvious error message appears, please wait patiently.
After the check is completed, please restore the file system.
Input:
btrfs check --repair /dev/mapper/vg0-lv0Just wait for the end of the recovery process and input:
/etc/tos/script/mntdata9. Refresh the TOS login page and log in again.
