USB Copy:Run the backup only take 1 minit . Not update mirror
The brand-new USB Copy not only provides common backup features, in order to realize offline backup and defend against threats from external networks.
adamkor
Post by adamkor »
Explain problem :
USB Copy after create the backup info , run the backup only take 1 mint .
checking usb storage not mirror update.
adamkor
Re: USB Copy:Run the backup only take 1 minit . Not update mirror
Post by adamkor »
I find the problem. my ext usb is ntfs , need to format as ext4 . after testing folder is create but not all the data is backup !
Thank you for your feedback, we will verify the related issue.
adamkor
Post by adamkor »
Any more info you like to collect ?
Return to “USB Copy”
