create user with SSH access
Mnemosys85
Post by Mnemosys85 »
I am trying to connect via ssh to my NAS to do some changes to the nextcloud config file.
ssh root@IP -p 9222
root@IP's password:
Permission denied (publickey,password).
I am using the admin password but I always get this 'Permission denied' message.
I tried to change the password but there is no 'admin' user in the list. The only user in the list is the user (mynas) that was created when I set-up the NAS server.
I had a look through the help section on the NAS and found this:
The only problem is that when I try to create a new user I don't have that tick box to allow SSH access for that user.
Does anyone know what password I need to use? The only password that I ever used through the setup process was the password for my login and that doesn't work for what I need to do.
djonesuk
Re: create user with SSH access
Post by djonesuk »
The file you would need to edit is /etc/ssh/sshd_config. Change the line
AllowUsers admin
(where admin is the name of your TNAS admin user) to
AllowUsers admin fredsmith
where fredsmith is the username you wish to give ssh access
riparid971
Post by riparid971 »
djonesuk wrote: ↑24 Aug 2021, 06:10 The file you would need to edit is /etc/ssh/sshd_config. Change the line
AllowUsers admin
Thanks, it worked! Was facing a similar issue.
Hi team, thanks for creating such an active forum.
