I've been having issues with my F4-210, it's not newly bought, it was working fine for better part of a year, but this morning I found my TNAS beeping and it wouldn't stop, so I turned it off and proceeded to reboot it, once it reboot I could not access the files through W10 and when I try to login through TNAS PC App, I get the initialization screen and I click start, it checks my HDDs and it shows "Good" on both of them, so I continue and select online installation, but in the installation process I get the following message:
"Failed to create partition! Please try again.
If it still fails, your hard drives may have malfunctioned. Please initialize your hard drives and try again. If you continue to see this error, you may need to replace your hard drives"
as of now I can't seem to be able to use my TNAS at all. My setup is 2x Seagate Ironwolf 2 tb HDD on RAID 1
Appreciate your help
F4-210 Issue
- sianderson
- Silver Member
Re: F4-210 Issue
it sounds like the parition thats set up for the TOS has an issue and has got itself all confused
if you dont mind losing any data thats on the drives, i guess the ultimate solution is to put the hard drives in a PC, remove all partitions and then put them back in to the nas drive, this should see them as fresh new hard drives for it to then install TOS onto as if you have just bought it
F2-424 TOS 7.0.1278
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Re: F4-210 Issue
Well that's the issue, the files in the NAS are important so I'm trying to find a solution that doesn't require me losing that data.
Re: F4-210 Issue
Hi! When installing the system, if the word "format" appears, please do not continue, otherwise data will be lost.
It is more likely that the hard disk has a bad connection. Please unplug and plug the HDDs and then turn it on again. If the problem persists, please try using one of the HDDs to boot and report the result.
You can contact our tech team for more help.
Re: F4-210 Issue
I have tried booting with each HDD separate and reinserting with no success.
The only difference when i try each HDD separate is that at the drive check screen instead of getting a "Good" status, I get "At Risk" what could it mean?
Re: F4-210 Issue
Hi! You need to confirm whether there are bad sectors and the extent of the bad sectors in the hard disk.
You can refer the article. viewtopic.php?f=75&t=1125
- sianderson
- Silver Member
Re: F4-210 Issue
please chalk this one up to another example of how TM should have used their own boot drive to enable the nas drive to function, even if there are bad sectors on the users hard drives, poor designTMSupport wrote: ↑19 Aug 2021, 10:31 Hi! You need to confirm whether there are bad sectors and the extent of the bad sectors in the hard disk.
F2-424 TOS 7.0.1278
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- scoobyfizz
Re: F4-210 Issue
my new synology arrives in the next few days.. another reason why the Terramaster will be on ebay come Monday... Amusing how I am replacing a virtually new NAS with a 5 year old model..sianderson wrote: ↑19 Aug 2021, 15:58please chalk this one up to another example of how TM should have used their own boot drive to enable the nas drive to function, even if there are bad sectors on the users hard drives, poor designTMSupport wrote: ↑19 Aug 2021, 10:31 Hi! You need to confirm whether there are bad sectors and the extent of the bad sectors in the hard disk.
Best thing I ever did was ebay my Terramaster...
Re: F4-210 Issue
I'm in the process of "downgrading" my network to the same 5 year old equipment that was "upgraded" to the network manufacturer's "latest and greatest". The specific new capabilities which made the new equipment desirable got hosed by a mandatory firmware update. No reason to keep using the new equipment since it isn't outperforming the old equipment without using the non-functioning capabilities.scoobyfizz wrote: ↑19 Aug 2021, 22:28my new synology arrives in the next few days.. another reason why the Terramaster will be on ebay come Monday... Amusing how I am replacing a virtually new NAS with a 5 year old model..sianderson wrote: ↑19 Aug 2021, 15:58please chalk this one up to another example of how TM should have used their own boot drive to enable the nas drive to function, even if there are bad sectors on the users hard drives, poor designTMSupport wrote: ↑19 Aug 2021, 10:31 Hi! You need to confirm whether there are bad sectors and the extent of the bad sectors in the hard disk.
@scoobyfizz good luck with your new Nas.
- sianderson
- Silver Member
Re: F4-210 Issue
its a tough one, while i do understand the issues, i'm actually quite happy with my F2-210 now that i understand its limitations but it works fine for my home use, touch wood though that because i have a daily USB backup although its been a pain in the past, its relatively straight foward to restore the data from it
F2-424 TOS 7.0.1278
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1278
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
