F2-210 > SINGLE DISK > No BTRFS Option
- aSystemOverload
I've installed a 16TB HDD in my new F2-210, but am only given the option of formatting as EXT4, how do I get the option for BTRFS?
Re: F2-210 > SINGLE DISK > No BTRFS Option
F2-210 does not support btrfs file system.
- scoobyfizz
BTRFS works but it has to have been already created in previous version of TOS.
However the Terramaster website is misleading / confusing as it still shows that BTRFS is a supported file system so people are still buying this thinking it actually does like the OP.
Best thing I ever did was ebay my Terramaster...
- aSystemOverload
- sianderson
- Silver Member
what you actually mean is the F2-210 does not support the creation of btrfs file system ANYMORE since a recent update
it would be more useful if you can provide a fuller explanation to people asking the questions
it used to but this support has now been turned off due to issues with the TM software it was deemed more appropriate to stop users from using it than fixing the root cause of the issues
F2-424 TOS 7.0.1298
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- aSystemOverload
@sianderson thanks for the updated info. Would be nice if Terramaster had volunteered this themselves...
Because of technical issues, btrfs has been removed from 4.2.13 and later versions.
And we will check again and correct the wrong pages. I am sorry for that.
- Saijin_Naib
{L_BUTTON_AT}TMroy
