How can i secure my NAS
Greetings,
as i looked in my system protokolls i saw some wierd access from the internet to my NAS.
The first question is what are this for ports and what does it mean that they "Logout" to it.
The second question is, how can i secure my NAS that only local access can be done?
As my Local ip adress range is 192.168.179.*. . I see that there are firewall rules options but can't find a document
what i have to add.
Sincery Yours
what i have to add.
Sincery Yours
Re: How can i secure my NAS
Hi, "Port" means client port, and "logout" means that the user logs out on the web.
For firewall, you can go to Control Panel -> General Settings -> Security -> Firewall, create firewall rule, and then set allowed ip range.
- Saijin_Naib
{L_BUTTON_AT}TMSupport
- sianderson
- Silver Member
if you only want local access to the nas, can i ask why are you exposing it to the internet?
surely no one can attempt to login from the internet unless you port forward the port from your router to the nas drive?
F2-424 TOS 7.0.1298
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- Saijin_Naib
{L_BUTTON_AT}sianderson
I would like to have multi-layered firewalls just for redundancy/peace of mind. To say I'm nervous about my NAS being exploited would be an understatement.
- sianderson
- Silver Member
you are still not answering the question, how is someone able to come in from the internet and hit your nas drive if you are not exposing the ports from your router
out of interest have you set up TNAS online (which will open up the ports to allow communcation) or something like that? this would suggest your router is forwarding packets from the internet to your NAS drive in which case you do not have a functioning firewall on your router?
when you say you have a few ports open for normal usage what are they? are any of them targetting your nas drive?
F2-424 TOS 7.0.1298
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
F2-423 TOS 7.0.1298
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
- Saijin_Naib
No, TNAS Online is disabled.
Regular service ports are opened. I'm not listing them all. No port forwards/triggers to my NAS.
It likely isn't exposed at all. I just don't trust it.
So after some time now ago,
my NAS is also not exposed to the internet and i also see requests from the web.
So again my question to please providing an example how only to allow internal ports like 192.X.X
Sincerly Yours
Sincerly Yours
{L_BUTTON_AT}deex
Go to Control Panel -> General Settings -> Security -> Firewall, create a firewall rule, and then set allowed ip range.
You can also refer to the TOS help: https://help.terra-master.com/TOS/view/ ... g/SecurityTo contact our team, please send email to following addresses, remember to replace (at) with @
To be honest, you should be securing your network from your router.
This should be the first stop when protecting yourself from internet access.
You only need to set up a firewall on the TNAS if you want to protect it from internal traffic.
Bikers know why dogs stick their head out the window.
TNAS F5-221
TOS 4.2.39-2203011626
3X WD RED PLUS 3TB (RAID5)
2X WD Green 2TB (RAID1)
1X WD 4TB USB
TNAS F5-221
1X WD 4TB USB
