oauth.terra-master.com
KHnats
Post by KHnats »
See link. My TNAS are both behind a Firewall and I block most connections. I’m seeing a lot of oauth.terra-master.com connection requests, uploading around 10 mb and downloading around 60 mb daily.
What is the oauth.terra-master.com connection for? What data is transferred?
Re: oauth.terra-master.com
Hi!
This problem may be caused by opening the cloud drive sync.
And which cloud sync software do you have installed?
KHnats
Post by KHnats »
TMSupport wrote: 05 Aug 2021, 11:34 Hi!
Using Backblaze
KHnats
Post by KHnats »
As per previous post, I am using backblaze. Any issue should I block oauth.terra-master.com?
oauth.terra-master.com is used for authentication when you try to connect to your cloud drive account. If you block it you may not able to pass the authentication. This issue of traffic may because user activate the authentication, but he did not finish the process, so the cloud sync app keep request to the server. We will improve this part in future releases.
KHnats
Post by KHnats »
Thanks. I will simply block it by Firewall.
What is app.terra-master.com.w.cdngslb.com for?
I can see it is your CDN, not what it is for.
Hi! The App in our application center is cached by Alibaba Cloud CND, so when downloading and installing the application, it will communicate with this link.
KHnats
Post by KHnats »
TMSupport wrote: 16 Aug 2021, 09:19 Hi! The App in our application center is cached by Alibaba Cloud CND, so when downloading and installing the application, it will communicate with this link.
Return to “Network”
