ClamAV disappear in 4.2
Helge
Post by Helge »
What happend til ClamAV? It seems to have disapeared from latest update 4.2.xx
Thank you
Re: ClamAV disappear in 4.2
Do you mean that ClamAV cannot be found in the application center? If not, you may need to re-download the application due to the system version before the update.
Helge
Post by Helge »
Thank you for the answer
Where do I find previous versions og are there any risk involved in going back to an earlier version?
I updated to this 4.2.08
So you are suggesting that I go back to the previous 4.1.32?
Thank you.
You can uninstall this app from the installed list in the app center, and then download this app again.
Helge
Post by Helge »
Thank you for getting back to me.
The ClamAV app isn't installed. It has disappeared from the latest update 4.2.08 - it was in the app list on the 4.1.X update.
Question 1:
Can I find the app (ClamAV) somewhere and install it.
Question 2:
If not will a roll back to the previous software TOS Installation Package 4.1.32
Question 3:
Will softwareversion TOS Installation Package 4.2.14 work on my F2-410
Thank you
If your TNAS model is F2-210/F4-210, you cannot download this application temporarily because it has some problems and is temporarily removed. You can only wait for us to relist it.
You can choose the installation package according to your TNAS model: viewtopic.php?f=28&t=2119
Helge
Post by Helge »
Thank you
I'll wait for the upcoming update
Do you know when that will be?
Thank you
Return to “Others”
