It is possible that each update my PLEX go down?????
Now please GIVE ME THE SOLUTION TO HAVE AGAIN MY PLEX ONLINE!
E.
sounds like passing the buck here, surely its not a plex issue when the only thing that changed was a TM update?
only issue with this is TM's version of plex is usually quite a few versions behind the latest plex versionkenny31 wrote: ↑20 Jul 2021, 04:44 I found that if you failed to update plex before updating to 4.2.14 that plex would loose everything and needs to be rebuilt and yes I was able to test this theory as I have 2 identical terramaster nas drives and updated plex before installing the update and had no problems with plex on second device. So best to update everything if available before installing any TOS update.
