Setting up mail server
jasonyeap
Post by jasonyeap »
Im new to the community, trying to setup my mail server, unfortunately POP3 is not in FoxMail anymore.
The link I followed, I have successfully done the first part, now the remaining part if to login to my private mail account, can anyone help? Im using F2-210
https://www.programmersought.com/article/3197148042/
Re: Setting up mail server
Do you want to set F2-210 as the Mail Server? Did you install Maria DB and Mail Server from the application center?
jasonyeap
Post by jasonyeap »
Yes, F2-210 as the mail server, now I’m able to use Thunderbird (mail client) to setup my email account, but when email are sent, one does not receives. Both email sit in the domain created in TM Mail Server
Are the receiver and sender within the same local LAN?
jasonyeap
Post by jasonyeap »
Yes, I’ve logged into both email accounts within Thunderbird. Same network segment, how can I troubleshoot if the traffic went through?
Please set as the following picture shows:
Return to “Others”
