TELNET ROOT PASSWORD LOST AFTER FIRMWARE UPDATE
tasete30
Spain
Post by tasete30 »
Hello I just updated to TOS_S2.0_Update_JM33_4.2.14_2106221502_2106221811 and excepto for some permission problems related to smb folders shared that after updating user right were solved I can't access to root user on telnet as previously I had.
I need that user to use dockers so it's a problem for me.
Do you know if there is a bug with this firmware?
I tried to update admin password but the same problem.
BR.
Re: TELNET ROOT PASSWORD LOST AFTER FIRMWARE UPDATE
You should SSH login as admin (or your default administrator's username), and run sudo -i and enter the login password again to get the root permission.
tasete30
Spain
Post by tasete30 »
Thanks, now it's working.
BR.
PS. Sorry but in previous versions you could login directly as root.
It's different since TOS4.2.12.
