Dangling Simlink
Brodieman
Dangling Simlink
Post by Brodieman »
I seem to be too fast for my NAS and in some renaming I have created some dangling simlinks. I can use putty and telnet and see them. I cannot create a share with these names now because of it. How can I fix them? I have tried some file operations on them but I get permission denied, I am in as admin on telnet.
Thanks!
Re: Dangling Simlink
You can try to use the "sudo -i" or "sudo su" command to switch to the root user for operation.
Brodieman
Post by Brodieman »
TMRyan wrote: ↑04 Jul 2021, 12:38 You can try to use the "sudo -i" or "sudo su" command to switch to the root user for operation.
Anytime I try to use sudo I get,
sudo: command not found
Please try to clear the browser cache and then try doing this on the TOS page.
If the problem persists, the system configuration may be incomplete for unknown reasons.
Please try to reinstall the system, or send an email to the technical support mailbox so that we can arrange a specialist to check it for you.
Brodieman
Post by Brodieman »
Reinstalling is not an option. I have 10tb worth of stuff that would have to come off. Not doable. I'll email support.
