setting up SMTP with no auth
robertkwild
Post by robertkwild »
hi all,
i would like to set up my TNAS to my SMTP relay and im struggling, prob because it requires no auth to connect to
email rec 1 - [email protected]
smtp server - my smtp relay ip
port - 587
username - shall i put in the from address here, ive tried blank
password - does not require a password, so i leave blank
auth method - --------
thanks,
rob
TMS
Re: setting up SMTP with no auth
Post by TMS »
Did not quite understand, how do you do it? (Can be attached an attachment).
