What makes Seagate Exos drives be listed as “Applicable, not recommended”? What do they lack that the recommended drives have? And/or what extra “features” do they have that make them unsuitable?
What do you mean by Applicable, if they’re not recommended? Do you mean that, although they will work better than the other not recommended drives, they still do not meet the full requirements you set for “Recommended” drives? If so, again, which requirements are they missing?
To generalize further, since I realize that you will not have tested every drive made by every manufacturer, is it reasonably safe to choose a drive in the EXACT same product line from the same manufacturer as those for which you’ve recommended all of the other drives in that line so long as you haven’t singled it out as not recommended?
And finally, what happens if I do use non-recommended drives? Does the TNAS not work or is is simply less reliable? Does it void my warranty or mean you won’t offer me support?
Thanks in advance for responding to my annoying need to understand why things are the way they are!
