How do I delete folders in File Manager?
aj42b
Post by aj42b »
There isn't any command to do so.
cheers
Aj42b
Re: How do I delete folders in File Manager?
Do you want to delete shared folders or sub folders? Do you mean to delete in File Manager on TOS web page?
aj42b
Post by aj42b »
Yes, I'm referring to the File Manager on TOS web page.
I don't know how to manage the folders any other way.
I also don't know which of the apps might be useful for this type of action.
To delete a shared folder from TerraMaster TNAS, go to TOS desktop > control panel > privileges > shared folder
aj42b
Post by aj42b »
'To delete a shared folder from TerraMaster TNAS, go to TOS desktop > control panel > privileges > shared folder'
and then what?
TMS
Post by TMS »
Select the floder to be deleted, click Delete, but public and appdata are public folders that cannot be deleted.
aj42b
Post by aj42b »
What about the contents of the 'public and appdata' folders?
TMS
Post by TMS »
Yes, you can delete the contents of public and appdata in the file management.
