Thunderbolt 3 cable quality important?
PacoBelan
Post by PacoBelan »
Hey there,
I just bought the often here recommended Caldigit TS3 plus hub.
The cable is short, so I'm looking for a longer one.
TB3 cables a with 40gbps start at around 30€ for Chinese stuff on Amazon and go up to 100€+ for a cable sold by Apple.
Can I just take the cheapest or should I make sure it's done by a certain manufacturer?
Thanks a ton!
Re: Thunderbolt 3 cable quality important?
what is the length of the cable you plan to buy? A quantity TB3 cable length over 80cm normal cost at least $60-80. or even more.
