Restart Service
sianderson
Restart Service
Post by sianderson »
Restart Service continually using 30 - 40% CPU? whats this all about (nas wasnt doing anything)
i have since rebooted the nas drive and all now seems to be stable
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Re: Restart Service
It's a system service, it will be normal after reboot.
sianderson
Re: Restart Service
ok but why did it suddenly decide to start using 30 - 40% of the processor
you make it sound like it is perfectly normal, in which case why is not using the cpu now? and why did it suddenly decide to do it after 8 days of being turned on (with no changes to the system)
a process that decides to occupy 30 - 40% of the CPU without any changes being made is NOT normal and why should i have to restart my NAS drive every week? to prevent it from happening?
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
Re: Restart Service
If you look at the list, you will find there are two restart_service processes running. This may be the reason to cause your high CPU usage, we do not know what could be the reason, but we will check the possibility from the code shortly.
Return to “System Resources”
