Plex stops
ridinghero1990
Plex stops
Post by ridinghero1990 »
With the two newest updates, Plex stops every few days and I have to manually restart my server. Please fix this problem. It never happened before the last two Plex updates.
scoobyfizz
Re: Plex stops
Post by scoobyfizz »
Plex version on Terramaster is very out of date now. Hopefully three will be a new version soon. I found I had a problem once with Plex doing this and it was a problem with the scanning. Try looking at the logs in Plex to see if you have something in your libraries it does not like.
Best thing I ever did was ebay my Terramaster...
ridinghero1990
Re: Plex stops
I turned on logging and will monitor it.
ridinghero1990
Re: Plex stops
Turned off DLNA and it hasn't shut down in a few days. I noticed when scanning, Plex would spend a long time in the Music library. So I removed music for now. I will keep monitoring this.
Re: Plex stops
Ok, keep us informed if any updates.
