Can´t install or use PIP/Python
octekin
Post by octekin »
I can´t use pip.
I get everytime a error message.
-bash: pip: command not found
Please help. Thanks
Re: Can´t install or use PIP/Python
Can you describe your problem in detail?
octekin
Post by octekin »
Hey,
my problemm is that I can´t use the pip command.
For example when I try to install projects from https://pypi.org/project I get this:
error message through the SSH Putty connection.
I install both from the app manager Pyhton and PIP. When I write the command whereis pip I get this message:
whereis pip
pip: /mnt/md0/application/pip
And when I write whereis python I get this:
whereis python
python: /usr/lib/python3.6 /mnt/md0/application/bin/python3.6-config /mnt/md0/application/bin/python3.6m-config /mnt/md0/application/bin/python3.6m /mnt/md0/application/bin/python3.6 /mnt/md0/application/lib/python3.6
I try also to uninstall PIP and Python and reinstall, but without effect.
Please help
It seems that PIP has not been installed correctly. Please try to reinstall PIP. By the way,what is the version of TOS?
octekin
Post by octekin »
hey,
I reinstall it, and now it works 8-) . The version of TOS is 4.2.12-2104131759
Return to “Others”
