"Note: Mac OS computers do not support RAID online expansion"
edgley
Post by edgley »
Does this mean if I build an array with just three disks, as I am using a Mac, I cannot then add another two disks and expand the array?
thanks.
D5 /TB3 / 5x4TB
Mac Studio / macOS 26 - Tahoe
Re: "Note: Mac OS computers do not support RAID online expansion"
Please tell us your equipment model. And, where do you see such a prompt?
edgley
Post by edgley »
I have the D5 - 5bay, TB3 version.
it was in the online help, let me go find the link,
Its just over half way down this page:
http://help.terra-master.com/raidmanage ... ag/Logical
"OCE/ORLM: On-line expansion or migration of disk arrays. Note: Mac OS computers do not support RAID online expansion and migration."
D5 /TB3 / 5x4TB
In fact, D5-TD3 supports expansion and migration, but due to the limitations of MacOS, it cannot be implemented on MacOS. You can consider connecting to WindowsOS for expansion or migration, and then connect back to MacOS to continue using it.
edgley
Post by edgley »
Strange, cos I added another disk and it is migrating it in right now.
However, its been running for 7 hours and has only done 13%.
It is saying it will taken another 47 hours.
However, it is currently taking and hour to do only 2%!
Which means it will take 50 hours to add a fourth 4gb disk.
Or, put another way, over TWO days!
D5 /TB3 / 5x4TB
edgley
Post by edgley »
Migrating 23%
remaining time:75:27:29
D5 /TB3 / 5x4TB
edgley
Post by edgley »
Migrating 36%
remaining time:31:31:18
D5 /TB3 / 5x4TB
edgley
Post by edgley »
The result so far, 24 hours into this exciting nerve racking race :)
Migrating 40%
remaining time:28:42:29
D5 /TB3 / 5x4TB
pichento
Post by pichento »
Hi Edgley, i ve got the same problem, i m on mac os Catalina, i ve got a Terra Master D5 thunderbolt since 2 years with 3 hard drive of 10To in RAID 5 mode, i've just bought a new one of 10 TO again, i did everything to add it, everything seems ok but i'm still have only 20 TO and not 30 TO of space and impossible to change the size with disk utility that is stuck at 20 TO. In the RAID MANAGER PRO i've got my 4 hard drives, and the status is MIGRATING since 1 hour 0% and time remaining vary from 72h to 19h... I join a screen shot of my computer. I don't know if sometrhing will happen and if at the end it will work. So did it work for you at the end ?
