Registry config?
Discussion about Docker
RadicalDave
Registry config?
Post by RadicalDave »
Where is docker registry stored? I need to add a custom mostly public one. Thanks.
I'm guessing, I'll have to telnet and edit it from /etc somewhere?
Re: Registry config?
You can download an image at will and use the find command to view the storage path.Then try to customize your own。
Return to “Docker”
