F5-221 - Increase Volume - Ext4 - RAID5
cpradio
Post by cpradio »
I've read the following and the steps just are not working for me
viewtopic.php?f=25&t=1902&p=10335&hilit=volume#p10335
viewtopic.php?f=75&t=1543&p=8155&hilit=volume#p8155
I originally had 3 6 TB hard drives in a RAID5 array. I just recently added a 4th to the array and the sync process has completed. I see 16 TB available in the storage pool.
However, when I go to increase the Volume, it doesn't keep the changes.
Initial settings:
Updated to use max storage pool:
When I click confirm, it acts like it is saving the changes, but the changes are never reflected in the volume. Is there anything else I need to be considering? The volume is shared via a folder.
cpradio
Re: F5-221 - Increase Volume - Ext4 - RAID5
Post by cpradio »
Okay, seems that click MAX didn't work because it didn't want to use the entire free space. I changed it to
16669 (leaving off the .21) and it took it. Still says I have .20 left, but I'm good with this result)
Thank you for your report. We will fix it in future release.
ionelstefan
Post by ionelstefan »
thanks for help
Similar to metal detection, magnet fishing is about finding metal objects in the water using strong magnets. Have you ever imagined what could be at the base of the lake near where you live?
GeorgieH
Post by GeorgieH »
{L_BUTTON_AT}cpradio
Thank you for this info. I’ve spent hours trying to solve the same problem, as soon as I removed the numbers after the decimal point, the storage space increased immediately.
