owncloud Login
nog-bad-the-bad
owncloud Login
Post by nog-bad-the-bad »
Hi there,
I've just installed owncloud and it's asking for login! I've not set one up yet is there a default or can this be reset?
cheers in advance
Re: owncloud Login
Please SSH access your TNAS, and run the cmd lines:
vi /usr/local/web-ext/owncloud/config/config.php
modify line 47
change the value true to be flase
run owncloud then to reconfigure new user and database.
nog-bad-the-bad
Re: owncloud Login
Thanks support, however, config.php is empty!
"/usr/local/web-ext/owncloud/config/config.php 1/1 100%"
I un-installed owncloud then re-installed it just to check, but it is still an empty file!
Any idea?
Cheers
Warren
Re: owncloud Login
Please uninstall owncloud first.
Then run the cmd lines below to delete all the configuration files.
rm -rf  /mnt/md0/appdata/database/owncloud
rm -rf  /mnt/md0/application/pkgs/owncloud
rm -rf  /mnt/md0/application/pkgs/owncloud.tpk
rm -rf  /mnt/md0/application/web-ext/owncloud
rm -rf  /tmp/wget-owncloud
rm -rf  /tmp/databack/json-owncloud
Reinstall owncloud.
nog-bad-the-bad
Re: owncloud Login
@TMSupport,
Thank you, That worked a treat.... :D
all good now.
w.
penright
Re: owncloud Login
Post by penright »
TMSupport wrote: ↑20 May 2021, 15:22 Please uninstall owncloud first.
Reinstall owncloud.
When trying to remove '/mnt/md0/application/pkgs/owncloud' I am getting error. I have also upgraded to 4.2.13 x86 version.
/apps/files_mediaviewer/LICENSE': Permission denied
rm: cannot remove '/mnt/md0/application/pkgs/owncloud/usr/local/web-ext/owncl/apps/files_mediaviewer/appinfo/signature.json': Permission denied
rm: cannot remove '/mnt/md0/application/pkgs/owncloud/usr/local/web-ext/owncl/apps/files_mediaviewer/appinfo/app.php': Permission denied
If I try and use sudo rm, I get this error and it does not ask from the admin password.
sudo rm -rf /mnt/md0/application/pkgs/ownclou
sudo: /usr/bin/sudo must be owned by uid 0 and have the setuid bit set
Re: owncloud Login
{L_BUTTON_AT}penright
If you are running TOS4.2.13, you should SSH login as admin (or your default administrator's username), and run sudo -i and enter the login password again to get the root permission.
penright
Re: owncloud Login
Post by penright »
TMSupport wrote: ↑21 Jun 2021, 15:41 [at=penright post_id=11191 time=1624031239 user_id=2896][/at]
The same thing, sudo must be owned by uid 0 and have the setuid bit set. From reading the forums, this seems to be an issue for the last few versions.
TMS
Re: owncloud Login
Post by TMS »
Please refer to this link :viewtopic.php?f=23&t=2068
penright
Re: owncloud Login
Post by penright »
TMS wrote: ↑21 Jun 2021, 22:01 Please refer to this link :viewtopic.php?f=23&t=2068
I was expecting this, but I did exactly as the topic you linked if you look closely at the image I did exactly what I was supposed to do. Running sudo is where the issue is.
Return to “Others”
