Nextcloud over the internet - Can't access config.php permission denied
korani
Post by korani »
I was following the steps in this post:
viewtopic.php?f=41&t=1135&p=6127&hilit= ... ted+domain
to be able to access Nextcloud over the internet but when I tried to access config.php I got Permission denied message
I am using root username to SSH into the NAS
I am not professional with SSH so any help is appreciated :)
Re: Nextcloud over the internet - Can't access config.php permission denied
What's your TNAS model number and current TOS version?
korani
Post by korani »
my TNaAS is F5-221 and TOS version is 4.2.09 which is the latest when I try to run Software update
Please set the permission to the config.php file using the cmd line chmod rwx
korani
Post by korani »
Would you please provide the full command that I need to run? I tried to find the syntax online but I am not an expert
Why do you want to access the file ? You want to read it or edit it ? You don't need to change his permission.
Open it with an editor, like vi for editing
vi /mnt/md0/application/web-ext/nextcloud/config/config.php
if you want to just read it
cat /mnt/md0/application/web-ext/nextcloud/config/config.php
korani
Post by korani »
[at=outkastm post_id=10339 time=1620982001 user_id=2797][/at]
Thank you, I managed to edit the file as needed :)
Return to “CloudSync”
