IP 0.0.0.0
SergioSaar96
IP 0.0.0.0
Post by SergioSaar96 »
Hello, my tnas is the F2-221 and I have recently updated it to version 4.2.09 and I have installed Portainer from the application store, the application works correctly, but when I click on the port of a container, it opens the url 0.0.0.0:8080 for example, when it should be 192.168.1.100:8080.
Does anyone know why this happens? Thanks.
Re: IP 0.0.0.0
Thanks for the report, we have tested here and it's true as you reported. While since Portainer is a third party app, we cannot fix this issue. Please manually input the correct IP address.
SergioSaar96
Re: IP 0.0.0.0
TMSupport wrote: 11 May 2021, 10:43 Thanks for the report, we have tested here and it's true as you reported. While since Portainer is a third party app, we cannot fix this issue. Please manually input the correct IP address.
How can I do that? I tried to create a docker network with the correct host_binding_ipv4 but when I try to access the web page it never loads, it seems to only work when the ip is 0.0.0.0
Return to “Network”
