[TUTO] Enable SSH root access on fw >4.2.11
This how to switch ssh access from admin to root on TOS fw >4.2.11.
Note that this is not recommended but some experienced users prefer the ssh root access
Connect via ssh to NAS using the user admin, then type
sudo vi /etc/ssh/sshd_config
Enter you admin password and the ssh config file will open with vi editor
To be able to edit the file, we need to change vi in edit mode.
For that press on i
Now scroll down to this line
PermitRootLogin no
and adapt it to
PermitRootLogin yes
Scroll down more to this line
AllowUsers admin
and adapt it to
AllowUsers root
Now pres ESC key to exit from edit mode
To save and close the file, type :wq
Now reboot the NAS or from TOS WebUI disable and enable back ssh
sudo reboot
Open new ssh connection and now you can connect with root
1dimitri
Re: [TUTO] Enable SSH root access on fw >4.2.11
Post by 1dimitri »
Small typo:
connect as the first user you created during the TOS installation
and in the file search for that word not "admin".
E.g. if your 1St user was "adminaccount", log on as "adminaccount" and search for "adminaccount"
BTW, it is also a small precaution against script kiddies not to call own's administrator, admin, if possible ;)
Saijin_Naib
Post by Saijin_Naib »
If I made the mistake of using admin as my first account, can I change it now without breaking things?
1dimitri
Post by 1dimitri »
Support has to confirm
1. what will happen if you're using the (Windows) Application to search and connect to the NAS as there is a login button and a way to install the OS when the server is just unpacked, but I do not know what happen if tried on an already installed server
2. If there is a way to change the name using SSH and/or the Users part of the control panel
3. If there is a way endorsed by the Terramaster to do it using Linux Commands through SSH.
Not required anymore if you use OkmSSHD app.
