Is it normal that the app installation stuck at 50% while volume is synchronizing?
Kanuki
Thailand
Post by Kanuki »
Hi.. Guys..
I'm new to TerraMaster.
I uninstalled iSCSI Target Pro then I try to re-install it back.
The first time installed iSCSI Target Pro was very fast.
I'm not sure whether it's normal behavior or not.
Re: Is it normal that the app installation stuck at 50% while volume is synchronizing?
This should be the process of decompressing the application.
You can try to restart the device and download again.
Of course, you can also use SSH to log in to the terminal, and then delete the wget-iscsiadm process and /tmp/scri**/get.iscsiadm in the /tmp/ directory.
Return to “Others”
