[ Lidarr ] Music collection manager
About : https://lidarr.audio/
Applicable TOS5: 5.0.170 or later versions
Applicable TOS6: 6.0.420 or later versions
App download: https://tmnascommunity.eu/download/lidarr
Required packages:
ModBase1 > 1.00.08
http(s)://yournasip:port/modules/Lidarr/www - TOS4
http(s)://yournasip:port/Lidarr - TOS5
About
Lidarr is a music collection manager for Usenet and BitTorrent users. It can monitor multiple RSS feeds for new albums from your favorite artists and will interface with clients and indexers to grab, sort, and rename them. It can also be configured to automatically upgrade the quality of existing files in the library when a better quality format becomes available.
zway
Re: [ Lidarr ][ 0.8.1.2135.0 ] Music collection manager
Post by zway »
The app has issues with external connections over HTTPS,
Request Failed. GET /api/v1/update: The SSL connection could not be established, see inner exception. The remote certificate is invalid according to the validation procedure.: 'https://lidarr.servarr.com/v1/update/ma ... Ver=3.1.13'
All external connections throw these errors
Do you have latest ModBase1 module installed ?
Can you check the log file ?
Re: [ Lidarr ][ 1.0.1.2578 ] Music collection manager
up to 1.0.1.2578
jhalfhide
Post by jhalfhide »
Any chance of getting lidarr on tos5?
F2-422 running TOS 5.1
Plex/Sonarr/Radarr/Lidarr/SabNZBD
Will do
jhalfhide
Post by jhalfhide »
{L_BUTTON_AT}outkastm
Thanks for that, I can see it on the app page now. It is showing as 0.00kb though, with no download option.
Yes, busy on building the app
eulero
Italy
Post by eulero »
Can you add the download link on your pvt portal?
Thanks a lot as usual!
Eulero
Current System:
F2-422 - 4TB storage
TOS- 7.0.0333
jhalfhide
Post by jhalfhide »
outkastm wrote: ↑03 Dec 2022, 17:41 Yes, busy on building the app
Ah, apologies. I didn't know what the deal was. Many thanks for what you do
