F2-220 - Used Space location
GranityFly
Post by GranityFly »
A couple months ago I was playing around and lost a whole folder of media. I've scoured everywhere and I can't find them. I believe they are still on my raid 1 somewhere as it shows I have 165.44GB used out of 3.64T. That is the approximate storage of the media. I've checked the recycle bin and they aren't there. Any recommendations? Sorry for noob questions, I got a Nas to avoid this scenario and I don't see any kind of recovery scan or anything. Thank you in advance.
Re: F2-220 - Used Space location
As I do not know what you did to your device, but please try the followings:
1. go to control panel > shared folder > advanced;
2. restore your shared folder;
hopefully, it works for you.
GranityFly
I tried this with no success. Is there an app that will scan the nas for file recovery? I have yet to find one that will work. I've looked at alot of threads and tried alot of stuff. I got this nas assuming that since i have a striped raid that I would not lose data anymore. It seems like a nas is more for just rebuilding bad hdd. Thanks for your help
Did your data exist in a shared folder you created before? Or is it in a user's personal folder?
Can you still see the shared folder in the shared folder of the control panel?
If it is a user's personal folder, you can check the following locations:
How many volumes do you have? If the data exists in public or appdata, you can try to restore to your other volume a few more times.
Return to “File Services”
