issue with folders named "desktop"
erik.meuwese
Post by erik.meuwese »
Folders named "desktop" or "Desktop" cannot be copied. Could it be that TOS thinks that "desktop" should be in de user dir and not in a profile of a program or in a backup.
The setup is as follows TNAS F5-420 with TOS version 4.2.09 connected to PC with Windows 10. The destination folder "\\192.168.1.101\myussername\backup" on the TNAS mounted to "Z:\" and than in Powershell I use "robocopy D:\ Z:\backup-d /e /v". I use robocopy in this case because it can handle longer paths than windows explorer.
An application had a folder with "D:\someprogram\profile\mobile\config" and "D:\someprogram\profile\desktop\config". Then coping fails on folders "D:\someprogram\profile\desktop". For example MATLAB has a folder "desktop" in one of the plugins.
Also when using the webinterface then I cannot make folders named "desktop" in any dir.
It would be nice to be able copy any source folder to a folder on the TNAS without having to rename every "desktop" folder. Does someone know a solution?
TMS
Re: issue with folders named "desktop"
Post by TMS »
Thanks for your report, we will test and verify this issue.
{L_BUTTON_AT}erik.meuwese
Can't you copy it to TNAS or can't you copy it on your computer?
May I know the prompt when copying "D:\someprogram\profile\desktop" fails?
Is this application running and it is not allowed to be copied to other places?
We only found that the web interface in TOS hides the desktop folder, and the Desktop folder can be used normally.
erik.meuwese
On the PC i created the following dir structure with one txt file C:\test\desktop\test\test.txt. The test.txt has the content 'TNAS test' length 9 chars
Network drive Z:/ is mounted to the ip \\192.168.1.101\myusername and the dir backup does already exist. The dir tnas-test does not exist robocopy will create it.
Then open PowerShell and run 'robocopy C:\test Z:\backup\tnas-test /E /V'
The output:
     ROBOCOPY       ::          Robust File Copy for Windows
     Started  :  Tuesday, 20 April 2021  20:03:46
      Source  :  C:\test'
         Dest  :  Z:\backup\tnas-test\
        Files  :  *.*
    Options  :  *.* /V /S /E /DCOPY:DA /COPY:DAT /R:1000000 /W:30
               New Dir            0     C:\test\
               New Dir            0     C:\test\desktop\
2021/04/20 20:03:46 ERROR 2 (0x00000002) Creating Destination Directory Z:\backup\tnas-test\desktop\
The system cannot find the file specified.
Waiting 30 seconds... Retrying...
Rename the dir desktop to works. The source (PC) dir structure wil look like C:\test\works\test\test.txt
Then run 'robocopy C:\test Z:\backup\tnas-test /E /V'
The output:
      Source  :  C:\test'
        Files  :  *.*
               New Dir            0     C:\test\
               New Dir            0     C:\test\works\
               New Dir           1      C:\test\works\test\
100%       New File           9     test.txt
                 Total       Copied      Skipped    Mismatch   FAILED        Extras
   Dirs  :           3              2                 1                0             0              0
  Files  :           1              1                 0                0             0              0
 Bytes  :           9              9                 0                0             0              0
Times  :  0:00:00     0:00:00                                        0:00:00    0:00:00
Speed  :                    600 Bytes/sec.
Speed  :                 0.034 MegaBytes/min.
Ended  :  Tuesday, 20 April 2021  20:03:46
When using Explorer to copy C:\test to Z:\backup you get the following:
alternative url for the image: https://ibb.co/8jff6Z9 (image host removes image after 2 weeks)
The dirs and file where not in use by any other program
erik.meuwese
Same test setup:
And test.txt has 9 characters of text in it.
Powershell
>scp -r c:\test [email protected]:~/backup
Password:
test,txt                                                       100%    9     0.0KB/s    00:00
> ssh  [email protected]
Password:
Welcome to Tnas!
$ cd ~/backup/test/desktop/test
$ ls
test.txt
With scp the dirs and file are copied. But visiting \\192.168.1.115\myusername\backup\test in Explorer then the folder "desktop is not visible
The smb.conf in /etc/samba shows:
veto files =  /desktop
However in TOS Control Panel -> File Service -> SMB/CIFS File Service under Advanced Veto files is unchecked.
In the Samba documentation it saids that the default is that no files or dirs are vetoed. And /*dekstop*/ would match the word desktop and /desktop the specific file.
The smb.conf is read-only and as user admin I cannot change the file rights?
How to access root?
erik.meuwese
Getting rights to change the smb.conf viewtopic.php?t=737
Editing /etc/samba/smb.conf and removing veto files = /desktop did not solve it. After rebooting veto files = /desktop is back in the config.
Return to “File Services”
