Plex and merging two libraries
DementedJohn
Post by DementedJohn »
I have plex setup on one TNAS and its running fine....but getting low. I have another TNAS on the same network, and it has roughly 10TB free space. I am wondering if there is a way to share a folder on the free spaced TNAs to the other NAS so Plex can find it and add it to the library?
TMRyan
Re: Plex and merging two libraries
Post by TMRyan »
You can modify the NFS permissions of the shared folder of one TNAS, and then use the other TNAS to mount the shared folder in the remote folder in the control panel.
After successfully mounting, you can use PLEX to add the database.
