Trying to login to NAS
jim.thornton
Post by jim.thornton »
Hello... I'm trying to login to my F2-210. However something looks VERY strange and I don't trust it. My TOS login page is different. When I go to the IP address, it now says XVR Login and has username, password and has TCP/UDP/MULTICAST as a third option.
This seems very weird to me. I looked at the source code for the login page and it is:
<!DOCTYPE HTML> <html> <head> <meta http-equiv="X-UA-Compatible" content="IE=edge"> <meta charset="UTF-8"> <title>WEB SERVICE</title> <link href="./baseProj/images/favicon.ico" type="image/x-icon" rel="shortcut icon"> <script src="ext/ext-all.js"></script> <script type="text/javascript" src="./projectPath.js"></script> <script type="text/javascript" src="/app/libs/require.js"></script> <script type="text/javascript" src="/app/jsCore/require-config.js"></script> <script type="text/javascript">Ext.onReady(function () {
            //启用缓存
            Ext.Loader.setConfig({
                "disableCaching": true,
                "paths":{
                    "basePath": BASEURL, //配置基础项目的文件路径
                    "projectPath": PROJECT_URL //配置定制项目的文件路径
            //定义项目的加载路径
            var basePath = Ext.Loader.getPath('basePath'),
                projectPath = Ext.Loader.getPath('projectPath');
            //设置类的地址路径
            Ext.Loader.setPath({
                "jsCore": "app/jsCore",
                'component': "baseProj/js/component",
                'js': 'baseProj/js',
                'plugin': 'app/plugin',
                'widget': 'baseProj/js/widget',
                'baseCls':'app/baseCls',
				'app': 'baseCls', //各个项目统一一个app
                'customJs': projectPath+'js', // 非基线项目引用的js路径
                'desktop':PROJ_MODULE.indexOf('desktop') != -1? projectPath+'js/desktop':basePath+'/js/desktop', //加载指定项目的Desktop.js
                'data': PROJ_MODULE.indexOf('data') != -1 ? projectPath + 'data': basePath + '/data'  //加载指定项目的数据文件
            //桌面内容不可选择
            Ext.getBody().unselectable();
            require(['pubsub','core','extend','libs/qrcode','libs/jsonpath','libs/json2',
                'libs/base64','libs/md5','libs/aes','libs/rsa'],function(){
                //载入必要的模块,字符串文件加载完成后,初始化和加载应用
                Ext.require(['jsCore.Common'], function () {
                    jsCore.Common.getJsonLanguage().done(function () {
                        //自验问题修改:设备初始化界面,密码输入框输入时,报js错误,修改为先设置规则
                        jsCore.Common.setFieldVtype();
                        Ext.require(['baseCls.App']);
                        //***密码输入框输入时,报js错误 END***//
        });</script> </head> <body></body> <script type="text/javascript" src="./pluginVersion.js"></script> <script type="text/javascript" src="./webVersion.js"></script> <script type="text/javascript" src="./cap.js"></script> </html>
Has someone hacked my TOS NAS??
TMS
Re: Trying to login to NAS
Post by TMS »
1. Make sure you have input a correct IP address and port;
2. Clear the browser cache, find the TNAS device through TNAS PC, and click login. Does another login page still appear?
Return to “Network”
