Hello I have 2 TD2 (1 TD2 and 1 TD2+)
I use the TD2 with 2 HDD in raid 0
Can I just put the 2 HDD in the other TD2+ ?
Will the TD2+ recognize the raid 0 from TD2 ?
Or should I build again the raid 0 and loss my data ?
THX !
PUT the 2 HDD raid 0 from TD2 to TD2+
- David besançon
Re: PUT the 2 HDD raid 0 from TD2 to TD2+
Anyone try this ? The Terramaster staff ?
The raid controllers of these two products are different.
You cannot use the raid0 mode hard disk made on TD2 products on TD2+ products.
It will not recognize the original Raid 0. You can only rebuild Raid 0, which will lose all your data.
