How To Schedule A File Download From Web
elimark1
Post by elimark1 »
Hello!
Does anyone know how to schedule TOS to download a file from the web, every 12 hours?
I am a new user. I come from OMW. Over there, you can schedule a file download using CURL.
Here is the command I used: curl -o newfilename.txt www .website. com/serverfile.txt -- minus the spaces in the URL. I just didn't want it this example to auto link.
Then, in the scheduler section, you can set the frequency of downloading the file.
What application could I install in TOS that would give me the same functionality?
Re: How To Schedule A File Download From Web
This requires you to write a simple script, and then use the command "crontab -e" to add timing tasks.
The scheduled task will be invalid after restart.
We are adding a scheduled task function to TOS, you need to wait for this function.
elimark1 wrote: 08 Apr 2021, 00:24 Hello!
You can use the 3rd party module Cron_okm to schedule your task. Jobs are persistent after reboot
Return to “File Services”
