Centralized Backup
Stevd
Centralized Backup
Post by Stevd »
I have just seen the beta Centralized backup, which I have just installed.
Is it possible to backup remote servers / computers using this app? What port is used for so I can set up the firewall / router?
Re: Centralized Backup
The application only supports backing up computers in the LAN, and connection in the LAN does not require a port.
Stevd
Post by Stevd »
Thanks for the update. Will it be developed to allow for remote backup in the future?
TMS
Post by TMS »
No, but you can choose other backup apps.
JCV
Post by JCV »
Maybe through a VPN tunnel?
yeah, a VPN service may be a better solution.
kennethmb
Post by kennethmb »
Will central backup perform deduplication and full image backup?
I'm currently using the UrBackup plugin but would like something that was a little more integrated.
{L_BUTTON_AT}kennethmb
No, currently we do not have deduplication inside the backup or system, but we have plan to add the deduplication feature in our TOS 5 later version.
Full image backup means disk image backup? Centralized Backup supports disk image backup.
titanrx8
Post by titanrx8 »
Is this the Aomei Centralized Backupper? Is there user documentation?
Centralized Backup is a different application and it's not Aomei Backupper. You can contact support(at)terra-master.com to ask for the user document of Centralized Backup.
Return to “Others”
