[ Python2 ][ 2.00.00 ] Programming language
About :
Last version: 2.00.00
Applicable models: TerraMaster x.64 series
Applicable TOS: 4.1.27 or later versions
App download: http://s.go.ro/ni0rz1hl
Required packages:
ModBase1 > 1.00.07
http(s)://yournasip:port/modules/Python2/www
Re: [ Python2 ][ 2.00.00 ] Programming language
added ver 2.00.00
brunix86
Italy
Post by brunix86 »
Hi outkastm,
Is it normal that when I open the app into the desktop I see only "(no access)" in the top-left corner?
My NAS Environment
  • TNAS F4-424
  • TOS 7.0.0777 (8GB System Partition)
  • 1x RAM Terramaster 8GB DDR5 4800 MHZ
  • 2x HDD Seagate IronWolf 12TB CMR [RAID1]
Not normal (will be adapted on next version)
But also that page is not really needed for this app as there is nothing to configure. Only to see the version installed.
This app is used as dependency for other apps that required Python v2.x
