[ Jellyfin ] The Free Software Media System
Re: [ Jellyfin ] The Free Software Media System
Try again
Spider
Post by Spider »
Got it thank you. Do I need to uninstall the one I have on there?
Spider
Post by Spider »
I must be missing a step someplace, because it's still not working.
27/03/23 22:28:14 The main volume is /Volume2
27/03/23 22:28:14  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:28:14 Will run as user: jellyfin and group: media
start-stop-daemon --start -c jellyfin -b --exec /Volume1/@apps/Jellyfin/bin/program/jellyfin -- -d /home/Over/MOD_CONFIG/Jellyfin/data -C /home/Over/MOD_CONFIG/Jellyfin/cache -c /home/Over/MOD_CONFIG/Jellyfin/config -l /home/Over/MOD_CONFIG/Jellyfin/log --ffmpeg /usr/local/ffmpeg/sys/bin/ffmpeg
27/03/23 22:30:22 The main volume is /Volume2
27/03/23 22:30:22  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:30:22 Will run as user: jellyfin and group: media
27/03/23 22:38:58 The main volume is /Volume2
27/03/23 22:38:59  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:38:59 Will run as user: jellyfin and group: media
27/03/23 22:39:10 The main volume is /Volume2
27/03/23 22:39:11  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:39:11 Will run as user: jellyfin and group: media
27/03/23 22:43:55 The main volume is /Volume2
27/03/23 22:43:55  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
27/03/23 22:43:55 Will run as user: jellyfin and group: media
28/03/23 05:20:39 The main volume is /Volume2
28/03/23 05:20:39  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:20:39 Will run as user: jellyfin and group: media
28/03/23 05:21:24 The main volume is /Volume2
28/03/23 05:21:24  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:21:24 Will run as user: jellyfin and group: media
28/03/23 05:21:48 The main volume is /Volume2
28/03/23 05:21:48  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:21:48 Will run as user: jellyfin and group: media
28/03/23 05:21:52 The main volume is /Volume2
28/03/23 05:21:52  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:21:53 Will run as user: jellyfin and group: media
28/03/23 05:28:48 The main volume is /Volume2
28/03/23 05:28:48  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:28:48 Will run as user: jellyfin and group: media
28/03/23 05:35:44 The main volume is /Volume2
28/03/23 05:35:44  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:35:44 Will run as user: jellyfin and group: media
28/03/23 05:36:21 The main volume is /Volume2
28/03/23 05:36:21  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 05:36:21 Will run as user: jellyfin and group: media
28/03/23 07:29:27 The main volume is /Volume2
28/03/23 07:29:27  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
28/03/23 07:29:54 The main volume is /Volume2
28/03/23 07:29:54  Config folder exist at /home/Over/MOD_CONFIG/Jellyfin
Can we have a TeamViewer session to identify the issue? The app should start automatically after install without any step from your side.
Spider
Post by Spider »
Hi outkastm,
yes we can. please provide a time and date.
up to 10.8.9.3 (fix startup issues on TOS5 for users with a previous TOS4 installation on drive)
momosa
Post by momosa »
{L_BUTTON_AT}outkastm
Has the problem been solved? I also have the same problem. After startup, the display is normal, but the port number is not up and cannot be accessed.
yes, startup for user migrating from TOS4 to TOS5 is fixed.
If you have issues, send some screenhots with the app WebUI annd check the log files.
momosa
Post by momosa »
Oh, no, I have the same problem, but I upgraded directly from TOS5.1.29 to TOS5.1.31 version, and then I found that the application started and displayed normally, but the port number never got up. I checked the log and showed success. I checked with Tterra-master officials to check this problem, and they said it might need to be solved by developers. Then I found that there are more than one application in the community that is in this situation Jellyfin Fenrus radarr Transmission4 The above applications all have the same situation, displaying normal startup, but the port number has not been raised
start.log:
07/04/23 09:05:09 The main volume is /Volume1
07/04/23 09:05:09  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
07/04/23 09:05:18 Will run as user: jellyfin and group: media
start-stop-daemon --start -c jellyfin -b --exec /Volume1/@apps/Jellyfin/bin/program/jellyfin -- -d /home/momosa/MOD_CONFIG/Jellyfin/data -C /home/momosa/MOD_CONFIG/Jellyfin/cache -c /home/momosa/MOD_CONFIG/Jellyfin/config -l /home/momosa/MOD_CONFIG/Jellyfin/log --ffmpeg /usr/local/ffmpeg/sys/bin/ffmpeg
08/04/23 09:05:09 The main volume is /Volume1
08/04/23 09:05:10  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
08/04/23 09:05:18 Will run as user: jellyfin and group: media
09/04/23 09:09:16 The main volume is /Volume1
09/04/23 09:09:17  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
09/04/23 09:09:24 Will run as user: jellyfin and group: media
10/04/23 09:05:03 The main volume is /Volume1
10/04/23 09:05:04  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
10/04/23 09:05:11 Will run as user: jellyfin and group: media
11/04/23 09:05:03 The main volume is /Volume1
11/04/23 09:05:03  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
11/04/23 09:05:11 Will run as user: jellyfin and group: media
11/04/23 18:36:28 Will use /Volume1 to store config files
11/04/23 18:36:28 The main volume is /Volume1
11/04/23 18:36:29 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
11/04/23 18:36:30 Will run as user: jellyfin and group: media
 SUCCESS!
11/04/23 19:35:23 Will use /Volume1 to store config files
11/04/23 19:35:23 The main volume is /Volume1
11/04/23 19:35:24 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
11/04/23 19:35:31 Will run as user: jellyfin and group: media
 SUCCESS!
11/04/23 19:47:08 Will use /Volume1 to store config files
11/04/23 19:47:09 The main volume is /Volume1
11/04/23 19:47:09 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
11/04/23 19:47:17 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 09:05:07 Will use /Volume1 to store config files
12/04/23 09:05:07 The main volume is /Volume1
12/04/23 09:05:08 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 09:05:15 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 11:13:25 Will use /Volume1 to store config files
12/04/23 11:13:25 The main volume is /Volume1
12/04/23 11:13:26 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 11:13:27 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 13:40:42 Will use /Volume1 to store config files
12/04/23 13:40:42 The main volume is /Volume1
12/04/23 13:40:43 Will use /Volume1 to store config files
12/04/23 13:40:43 The main volume is /Volume1
12/04/23 13:40:43 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 13:40:44 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 13:40:44 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 13:40:45 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 13:41:22 Will use /Volume1 to store config files
12/04/23 13:41:22 The main volume is /Volume1
12/04/23 13:41:23 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 13:41:23 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 14:47:13 Will use /Volume1 to store config files
12/04/23 14:47:13 The main volume is /Volume1
12/04/23 14:47:14 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 14:47:15 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 14:57:49 Will use /Volume1 to store config files
12/04/23 14:57:49 The main volume is /Volume1
12/04/23 14:57:49 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 14:57:50 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 15:01:06 Will use /Volume1 to store config files
12/04/23 15:01:06 The main volume is /Volume1
12/04/23 15:01:07 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 15:01:07 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 15:05:12 Will use /Volume1 to store config files
12/04/23 15:05:12 The main volume is /Volume1
12/04/23 15:05:13 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 15:05:13 Will run as user: jellyfin and group: media
 SUCCESS!
12/04/23 15:16:58 The main volume is /Volume1
12/04/23 15:16:59  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 15:16:59 Will run as user: jellyfin and group: media
12/04/23 15:25:11 The main volume is /Volume1
12/04/23 15:25:11  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 15:25:12 Will run as user: jellyfin and group: media
12/04/23 16:50:17 The main volume is /Volume1
12/04/23 16:50:18  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
12/04/23 16:50:18 Will run as user: jellyfin and group: media
13/04/23 09:41:14 The main volume is /Volume1
13/04/23 09:41:16  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
13/04/23 09:41:43 Will run as user: jellyfin and group: media
14/04/23 14:19:03 The main volume is /Volume1
14/04/23 14:19:06  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
14/04/23 14:19:13 Will run as user: jellyfin and group: media
14/04/23 16:35:26 The main volume is /Volume1
14/04/23 16:35:27  Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
14/04/23 16:35:27 Will run as user: jellyfin and group: media
16/04/23 12:25:26 Will use /Volume1 to store config files
16/04/23 12:25:26 The main volume is /Volume1
16/04/23 12:25:29 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
16/04/23 12:25:36 Will run as user: jellyfin and group: media
 SUCCESS!
16/04/23 14:05:52 Will use /Volume1 to store config files
16/04/23 14:05:53 The main volume is /Volume1
16/04/23 14:05:54 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
16/04/23 14:06:05 Will run as user: jellyfin and group: media
 SUCCESS!
17/04/23 09:40:37 Will use /Volume1 to store config files
17/04/23 09:40:38 The main volume is /Volume1
17/04/23 09:40:40 Config folder exist at /home/momosa/MOD_CONFIG/Jellyfin
17/04/23 09:40:58 Will run as user: jellyfin and group: media
 SUCCESS!
