Timeout and re-login
lolohz
Post by lolohz »
Hello
Could you please check if this behavior is an issue?
When my session is closed (by timeout) the browser shows me a form to login again. The first time I fill the data to login again they show a message saying "The user token has expired! Please, try again." If I try again it works fine.
Best regards.
sianderson
Re: Timeout and re-login
Post by sianderson »
this is perfectly normal, its been reported for a long time but never seems to get fixed (they have had more important issues to fix i guess)
F2-424 TOS 7.0.1536
F2-423 TOS 7.0.1536
F2-210 TOS 4.2.44
D4-320
C/O
F4-424 TOS 6.0.794
We are developing a control function that can control the logout time.
SunDogBC
Post by SunDogBC »
(This is my first post but this has bothered me since day one. :lol:)
It's not a question of the logout time. If it's been idle for a month and I come back, it should automatically refresh to the login page (as it does) then when I log in again it should just do it without telling me the token has expired and making me log in a second time. That part is obvious by the act of getting logged out in the first place.
Hopefully that gets fixed at the same time as the new control. Or maybe I can set to "never' and it won't matter. 8-)
F2-221 - TOS7.0.0403
BIOS/InitBoot version- MAPL0304V17
TNAS mobile (Android) - V3.5.044
Or just refresh the login page (F5) before you enter your credentials.
Return to “Network”
