Portainer app admin reset password
tecad64
Italy
Post by tecad64 »
i've installed Portanier application (as beta version) and it's work fine.
How can i reset the password? i tried unistalling the app and related configuration files but when i reinstall di app doesn't ask for new user ad password.
thanks.
Re: Portainer app admin reset password
When the device restarts, you can enter the new password to log in.
After you reinstall the APP, it will change back to the default login password.
iano
Post by iano »
Hope it's ok to jump in here and ask a related question.
I've just installed Portainer and it takes me direct to the login screen.
I've not been given the chance to set a username and password, I can't see any documentation other than first use it should prompt you to create a UN/pass.
Does it work differently on a Terramaster? Not quite sure what I should be typing in the boxes.
I've used Portainer before on a Pi3 with OMV but am a new Terramaster owner.
Am using a f4-221 TOS 4.2
This may caused by your explore caches, try to clean it.
After you login with admin/admin, you can set user password and permissions.
If you want to login with other account ,you can click log out.
iano
Post by iano »
Many thanks.
That worked an absolute treat. :D
Return to “Others”
